Issue with slow motion
(Topic created on: 09-03-2019 07:25 PM)
Gearhead
Hey everyone,
Am facing an issue when am doing some edits in the slow motion video and while saving it. Be it a minor or a major edit, the video doesn't get saved. Shows rhe error "Couldn't save video. Try Again". Is anybody else facing the same issue. Am facing it since few months i suppose.
PFA screenshot for reference.
Please let me know what's the issue and how can it be solved. It's not way related to the camera. Camera works with no issues. Just am not able to edit the slow motion videos from gallery.
Please let me know if there's a way to fix it.
2 Comments
Nuraddin
There is a workaround. In the video editor when you are done editing your slow motion videos, just tap once on any of the two while handles at the ends of the video timeline and it will then save the videos successfully. Or the problem arises if you change your display to a custom width in the developer options.
Logcat reader displayed the error as "unable to start animation. Surface is null or no children." Hope these helps.
Samsung_specialist
Please contact us on the Whatsapp Number 0558474355 so we can help you more efficiently.
