Issue with my s23u after oneui 6.1
(Topic created on: 03-30-2024 08:02 AM)
OmSingh04
I am using gestures navigation and this white/red(for some apps) line appears at the bottom of apps while going to home screen just bought this phone
Can anyone confirm if this is normal or there is a software/hardware issue?
18 Comments
OmSingh04
So its an issue for me only ig
TimonN
Expert Level 4
Ok, not with other apps?
OmSingh04
Its there for almost every app but i get that like 2-3 times trying to figure out if its software or hardware problem1711794145951.jpg1711794169121.jpg
TimonN
Expert Level 4
Check by changing theme if it makes any difference.
OmSingh04
Nope, still the same
Samsung_specialist
Follow these steps to Wipe cache partition
Turn off the device.
Connect To Computer or plug in USB-C Headphones , Press and hold the Volume Up key and then press and hold the Power key .
When the Android logo displays, release all three keys.
An 'Installing system update' message will show for 30 - 60 seconds before the Android system recovery menu options appear.
Press the Volume down key several times to highlight wipe cache partition.
Press Power key to select.
Press the Volume down key to highlight yes, them and press the Power key to select.
When the wipe cache partition is complete, Reboot system now is highlighted.
Press the Power key to restart the device
OmSingh04
This will help?
It may be an update, although it might not be the manufacturer's issue, given that a majority of individuals with different devices are experiencing the same issues. Consequently, the company appears to have no interest in addressing this issue.
If not, they know about it
