Issue while connecting s22 ultra with buds pro and watch 4
(Topic created on: 12-06-2024 10:36 PM)
ranjithpanakkadan
If i connect watch 4 and buds pro to my s22 ultra ,then other person cant hear my sound when an incoming and outgoing calls are made.
There is any settings to change ? I tried instead of buds pro with buds fe then it's works , kindly help me to solve my issue.. thank u
6 Comments
Didionpc
Check Bluetooth Settings:
Go to Settings > Connections > Bluetooth.Ensure both devices are connected and check if the audio output is set correctly.
Prioritize Audio Output:
When on a call, swipe down from the top of the screen to open the Quick Settings panel.Tap on the Audio output icon and select your Buds Pro as the preferred audio device.
Update Software:
Ensure your Galaxy S22 Ultra, Galaxy Watch 4, and Buds Pro are all running the latest software versions. Go to Settings > Software update > Download and install.
Reset Network Settings:
Go to Settings > General management > Reset > Reset network settings. This will reset all network settings, including Bluetooth connections.
Re-pair Devices:
Remove both the Galaxy Watch 4 and Buds Pro from your Bluetooth paired devices list.Re-pair them one at a time, starting with the Buds Pro, and then the Galaxy Watch 4.
Check for Interference:
Sometimes, other Bluetooth devices or Wi-Fi networks can cause interference. Try turning off other nearby Bluetooth devices to see if the issue persists.
Samsung Members App:
If the issue continues, use the Samsung Members app to report the problem. Go to Samsung Members > Get help > Error reports and provide details about the issue.
Thank u for u for your quick reply, sorry to say after trying all these only I wrote my issue..
I will try last one option to message support..
Didionpc
I would also suggest using the live chat option for support.
👍 thank u
Didionpc
At least I deserve one like. 😂
Samsung_specialist
Thank you for reaching out. It seems like there might be an issue with the audio routing when using your Galaxy Watch 4 and Galaxy Buds Pro together on your S22 Ultra.
Here are a few troubleshooting steps you can try to resolve the issue:
- Ensure both the Galaxy Watch 4 and Buds Pro are properly paired with your S22 Ultra.
- Try disconnecting and reconnecting both devices to see if that resolves the issue.
- When you receive or make a call, swipe down the notification panel and check if the correct audio output device (Buds Pro) is selected. It should show the device you're using for the call under the audio settings.
- Go to Settings > Apps > Show system apps > Bluetooth > Storage > Clear Cache. This can help resolve any Bluetooth connectivity issues.
- Ensure your Galaxy Watch 4, Galaxy Buds Pro, and S22 Ultra are all updated to the latest firmware, as updates can resolve compatibility issues.
