Issue in Developer mode, S24 Ultra
(Topic created on: 03-25-2024 03:42 PM)
KiranKing
Hello Samsung,
I am not able to view Developer options in Settings even though I tapped on Build Number 7 times.
If I go to Build Number again and
tap on it, it is saying
"No need, developer mode has already been enabled."
But in Setting at the bottom after About, it is not visible.
cs_member10
Dear Samsung Member,
As per your query, we request you to share the log file. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
