faraz4u
01-26-2023 12:53 AM (Last edited 01-26-2023 12:54 AM ) in
Hi Team,
Hope you are doing great.
Reaching out in regards to find a way, to silent my phone for only 1 sim.
I've using 2 sims, one for personal use and other one is for professional use.
I wanted to keep my phone to silent during my off working hours to not to get distracted.
Is there a way for it?
Thank you in advance.
Best Regards,
Ali
P.S: I've been using Galaxy S10 plus
5 Comments
Starshiv
01-26-2023 01:00 AM in
You can.
Just change the ringtone and notification tone of desired sim to "silent".
Starshiv
01-26-2023 01:01 AM in
Let me know if it helped and accept the solution.
faraz4u
01-26-2023 01:07 AM (Last edited 01-26-2023 01:08 AM ) in
Yeah it's a workaround. However, I've been looking for a single tap option.
Like as if I do, it will gonna silent the entire system.
Btw thanks for the kind suggestion.
Starshiv
01-26-2023 01:12 AM in
No such feature isn't available.
Click on three dots and accept the solution. It will help others to know this query has been resolved.
vinayshah
01-26-2023 04:42 PM in
Try routines and modes from quick panel.
