I'm having issue with s24 ultra system ui not responding
(Topic created on: 2 weeks ago)
IgNar
Beginner Level 4
Whenever I play games and quit the game it says systemui not responding close the app or wait , i have tried force restart and aslo clearing cache  of systemui , what should I do?
6 Comments
Fedron
Saiyan36
Bro try running benchmark test. And reset your Device to check if the issue still persists.
Or
Or
u can try booting your Device into safe mode and run your phone apps. Try to turn off developer options.
Or u can visit nearest service centre .. it may be a motherboard issue .
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You are welcome to here.
cs_member10
Dear Samsung Member,
● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
Shubh09desh
This similar issue i have been facing since OneUi 7
But still there hasn't been a solution for the same.
