I am using S20 FE 5G since last 5 days, It's Battery Consumption High.
(Topic created on: 01-04-2021 09:51 PM)
SunilBaba
I am using S20 FE 5G since last 5 days, It's Battery Consumption High. And the phone gets heat more than usual. Small brands like Xiaomi, Realmente are doing better, no idea why samsung is not able to beat them. Samsung team must do something to solve it.
12 Comments
Prathy
dont worry...u hav got lots of company.. exynos partners
SunilBaba
what do you mean? S20FE 5G has Snap Dragon 865, not Exynos.
Prathy
oh.. sorry, missed to notice its 5g. do a soft reset and try.. else better take it to service center.
adhamdarwish
It could be from the new update Android 11
SunilBaba
No, It has One UI 2.5 , Android 10, yet. Next month samsung will push One UI 3.0 and Android 11.
adhamdarwish
Why don't you download the update for all S20 phones, until the Note 10 happens
adhamdarwish
It may be that the Manzoo application is the reason to check the applications
SunilBaba
""Manzoo application"" ?
adhamdarwish
I mean, it is possible that the cause was from an app you downloaded and this app consumes the battery and raises the device's temperature
