wayricherthanyo u
a month ago in
Galaxy SIf your Samsung device freezes on the charging logo and refuses to boot up, don’t panic—this is a common issue that can be resolved with a simple button combination.
🔧 Step-by-Step Solution
1. Press and hold the following buttons simultaneously:
- Volume Down
- Bixby
- Power
2. Keep holding until the screen goes black and the device restarts.
3. Once the Samsung logo appears, release the buttons and allow the phone to boot normally.
💡 Why This Works
This combination forces a soft reset, clearing temporary glitches without erasing your data. It’s essentially like giving your phone a fresh start when it gets stuck.
⚠️ Pro Tip
If the issue persists after multiple attempts, consider:
- Charging with a different cable or adapter
- Checking for software updates once the phone boots
- Visiting a Samsung service center if the problem repeats frequently
4 Comments
The-Kid-Deė
a month ago in
I think you are stuck in 2019, Bixby button is no more
wayricherthanyo u
2 hours ago in
Yo $hut the f*ck up your not that guy
wayricherthanyo u
a month ago in
Some people like me are using the S series from that time which still supports the Bixby button so those are the people I am kindly addressing.
The-Kid-Deė
a month ago in
I see
