Horrible battery life of my S23fe
(Topic created on: 01-27-2024 09:34 PM)
Taha_Saud
I'm using this phone samsung s23fe from 2 months and got 2 updated but this phone has a battery issue it's not calibrated and solved it's battery drain like water I don't know what to do because neither a RS 18k phone did this. I'm experiencing significant battery drain issues after even half an hour of gaming and taking photos. Despite attempts to address the problem, it continues to persist. Means somehow companies can solve these issues through update.
10 Comments
MJ20
Follow Simple Steps ,After Every Update Wipe Cache Partition via Laptop ( Find Video on Youtube) put Unnecessary Apps in Deep Sleep mode ,Turn wifi Scanning n Bluetooth Scanning as They Run In back Ground, if Using Wifi keep data mode to 2G, Turn of Wifi calling options if still turned on, Don't use Ram Plus Option ,Its Factory Turned On ,It will Improve Battery Performance also ,Search auto battery optimisation, turned it on and also their be option of lite mode which helps prevents battery ,Turn Off Notifications of Apps you don't use Frequently, I beeen Using FE More Than a Month and It Gives me a Full Day Performance with Using social media ,Offical work and calls etc and i get around 8 hours plus screen on time with 19 or 21 Battery Still left,First Check the Option Via Youtube how to wipe cache Partition on S23 FE via Laptop Connect ,Belive me it works as it removes all old Unnecessary Junks
