Help
(Topic created on: 06-29-2020 04:38 AM)
Favourcoolboy
Please I want to know I my samsung s8 is water resistant?
MohammedSijah
"The Samsung Galaxy S8 / S8+ is rated IP68, using the Ingress Protection rating system. The dust rating is 6 (highest level of protection), and the water resistance rating is 8 (water-resistant up to 5 feet for up to 30 minutes)."
https://www.verizon.com/support/knowledge-base-211534/#:~:text=The%20Samsung%20Galaxy%20S8%20%2F%20S...).
4 Comments
MohammedSijah
sapmarvins
Yes, it is.
Favourcoolboy
am scared of mine , because it get hurt way too fast
aramis
i think you mean it gets hot so fast.. if you are uncomfortable of using the phone it us better to have it fixed by samsung service
