Help
(Topic created on: 07-12-2025 08:25 PM)
fenekX
There is no moisture in my port its showing from morning i can't charge my phone because of this what should i do?
11 Comments
Maybe you should try restarting your device (if it was a glitch , it will go away ) , otherwise change the charging port
fenekX
I tried everything
Maybe give it to the nearest customer care center
Please do try restarting it
Maybe the issue is resolved
Saiyan36
Use hair dryer
Courage13x
Same issue
vuvek
mdsalman1
My charging problem solved
mdsalman1
