Resolved! Solved
Help me out naa!
(Topic created on: 12-31-2019 07:06 AM)
cricketsq116
I've got a S10+ from UAE airport and am using it here in India.
Would there be some issue,due to that?
I've read somewhere that we need to first add dubai sim and then restart and keep Indian sim, for it to work; but I've just kept the Indian sim and it works like a pro!
Well, now that i see ads in this members app which shows "item worth 899UAED", I've become a bit concerned about the place of buying..
Well, please say something or some link which highlights the issues of using uae samsung mobile here, at India.
Cheers!😁
Ahmed6
your device will have access to Samsung Members app in GULF ( includes UAE,Qatar,KSA )
5 Comments
Ahmed6
cricketsq116
even though I am in India?..
can i do smthing about it?..
thanks
SGill
The device will work perfectly fine and you will face no issue.
since the device belongs to the gulf region so you are connected to Samsung Members of UAE.
I don't think you should worry about it.
cricketsq116
i dont have the call recording option😁
cricketsq116
also, the samsung pay has BHIM UPI (an indian service)
thanks for your help, but there ARE things i need to worry
