Help me guys!!
(Topic created on: 10-22-2024 05:08 PM)
Veduz
How to change AOD clock size in samsung s23 ?
8 Comments
subaldutta
Check it on lock screen
Veduz
Nothing is happening with the lock screen!
Mayur000
Long press on blank area of home screen,
Choose walpaper and style...
Then choose lock 🔒 screen, and then click on clock to adjust size, font, style.. last press ok.
If you got it then press three dots and accept solution.
Veduz
There is a difference between lock screen and AOD. So I know the lock screen information, but I need to get the AOD information.
Veduz
If anyone has any further information please let me know ?🙏
You cannot change
Veduz
You are right
Veduz
Suppose I reduce the size of the clock of Always On Display using lock star. So the size becomes small but the position of the notification icons below it which are with the clock and the position of the clock becomes different. What is the use of customizing the Always On Display, when we cannot customize it according to our need. I hope this problem will be solved in the next update and I and all the users using Always On Display will not face any problem.
#samsung #lockstar
