Help, S7 sensors problem
(Topic created on: 08-19-2018 07:48 AM)
Mazony
Hey guys so a month ago my mobile fall and a small leak happend next to the proximaty sensor,
it made no problems at all and everything went good, the leak in the screen is soo small, i use to put it or wash it under water with no troubles, yestarday i went under swimming pool for like 20minutes had no issues, seen some moister inside but no problems, today i went to the sea for snorkling and i took it under the sea for like 5 minutes then got it out, when i gone home the proxi sensor and light sensors are not working at all, i even tested them on *#0*# they dont work, i know i messed up but maybe when the mobile gets very dry it can get fixed ?562d48ba-7181-43f3-8ad5-0509c461def1.jpg
3 Comments
Mazony
zurayan
dude it's a phone not a submarine, probably u damaged it's motherboard
me paso lo mismo, reinicialo varias veces o dejalo apagado por varias horas, se te va pasar
