Heating issue & battery draining
(Topic created on: 02-07-2025 05:55 PM)
sooraj-k-sidharthan
After security update of January 2025.. my s23 ultra is facing heating issue & battery drain faster than before... anyone facing this issu???
3 Comments
Same issue with S24
Didionpc
Yes, it seems like you're not alone! Several users have reported similar issues with their Samsung S23 Ultra after the January 2025 security update.
Here are some troubleshooting steps you can try to address the heating and battery drain issues on your Samsung S23 Ultra:
Restart Your Device: Sometimes a simple restart can resolve temporary issues.
Check for Additional Updates: Ensure your device has the latest software updates installed. Go to Settings > Software Update > Download and Install.
Disable Unused Apps: Close or uninstall apps that you don't use frequently, as they might be running in the background and consuming resources.
Adjust Settings: Lower your screen brightness, turn off unnecessary features like Bluetooth and Wi-Fi when not in use, and enable power-saving modes.
If your question has been answered, please press the "Accept as Solution". You will find this in three dots to the right of my comment.
I did these all when i start facing the issue... but still same
