11-30-2020 03:01 PM in
Galaxy S- Mark as New
11-30-2020 03:08 PM in
Galaxy Seven you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Settings>>Connection>more connections settings> disable nearby device settings
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
11-30-2020 03:09 PM in
Galaxy S3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
12-01-2020 10:50 AM in
12-03-2020 01:22 PM in
Galaxy SDear Samsung Member,
Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
