Heat up/ changing heat
(Topic created on: 04-12-2024 09:20 PM)
Othy
Samsung S24 Ultra heat up while changing.
Anyone has the same issue like me ?
14 Comments
Zammi
It's normal to heat up a little. especially depending on room temperature as well. And if you're using fast charging, it's a bit higher side. Enable battery protection that gives extra protection.
Othy
Thanks for your reply.
My room is always cold, but I do have a super fast charger, and I change the phone 📱 only until 80 percent.
But I feel in the first days was not heating up.
Thanks
Try using battery Protection to adaptive
Othy
I did
What's the update
Othy
@smokin we are waiting for that to be solved
Still heating coz mine don't
Othy
Yes, still when I put it in charge
Othy
Hopefully yeah
