Highlighted
gerardjethro
GOOD PM
Help me i need an advice some off my apps crush like
FB messenger
What will i do REST FACTOR is my last option
HELP
Highlighted
Hi! Please try to uninstall and reinstall the FB messenger app.
Highlighted
gerardjethro
no need to rest factor??
Highlighted
gerardjethro
its still app crush even i reintall the messnger and Facebook
will i rest factor???
Highlighted
aramis
give it a try
Highlighted
gerardjethro
if i rest factor what will happen, the android 10 will still remain sir
Highlighted
EzEr4tin
bro walang kinalaman ung update ng android10 s problem mo sa fb.. bat di mo itry ilogin sa ibang phone or sa computer ung fb mo kung gnun prin.. sbi ko sau ireport mo s fb yan hahaha..
Highlighted
gerardjethro
ito ng sisi ako ng rest factor ako, huhu nawala mga file ko, ngayon start ako sa zero
Highlighted
gerardjethro
since when bro pa yung problema sa FB keep on stopin issue bago
Highlighted
EzEr4tin
matagal n yan n may gnyan sa fb,. bka may ngreport sau dyn, kaya nga sbi ko sau ireport mo sa fb yan pra maayos, may gnyang encounter nrn ang friend ko... nireport lng nya yan tpos nging okey na. walang kinalaman ang phone mo dyn. kahit ilang beses mo ireset phone mo andyn prin yan, kahit s computer ka mag login gnyan prn yan.. 😉
