Highlighted
Still i can't post with picture using facebook
And also i can't play even here messenger
Help last resource REST FACTOR
31 Comments
Highlighted
Hi, please contact us on our toll free number 800 7267864, and our customer service team will help you with your issue.
Highlighted
what will i do, if iam going to go rest factory or not
Highlighted
Hello
What will happen if im going to REST FACTOR ?
Plz help help
Highlighted
Its my biggest mistake to update my samsung s10 to android 10, its affect the facebook crush app, i cant able to post pic only text, my own solution is MYSTORY
Highlighted
your phone has nothing to do with your fb problem tol.. report your problem to facebook.. try logging your account to different device or computer..
Highlighted
What is rest factory?
Iam afraid to reset factory my samsung s10 android 10,  but if iam going to do it i need second opinion ?
Highlighted
Reset Factory is a formatting system for mobile devices, it means phone resetting as its original manufacturer settings.
You can remove data from your phone by resetting it to factory settings. Resetting this way is also called "formatting" or a "hard reset."
A factory reset erases all your data from your phone.
If you're resetting to fix an issue, you can do it. If there is no issues then i recommend you not to do so....
Highlighted
good am sir
the cause of reset to the original form is may facebook is not working well, i can't post with picture or video it kept closing what will i do
Highlighted
Still i can,'t post in my facebook some pictures, im using right know i MY STORY
my last option si rest factory
I need your opinion if im going to rest factor
