Green tint in s9 plus at low light
(Topic created on: 09-05-2020 10:46 AM)
bykreddy
Green tint in display in low brightness in my s9 plus,
Recently applied uv tempered glass on screen.
I have applied uv light little longer time around 5 to 10 mins to avoid bubbles, will it cause the issue.
For cross check i have removed tempered glass and cleaned screen but still green tint is persist.
Please share feedback.
20 Comments
Not applicable
no uv wont cause that issue
bykreddy
thanks
Not applicable
there must be the external pressure involved or software issue
bykreddy
no damage to my phone, may be software issue
Abusaleh77
yaa bro same problem after update
bykreddy
did u got the same issue after August update
Abusaleh77
Yaa bro even not me my 4 friends who using s9+ have same problem after update of august patch... it is not a screen problem it is a software problem
bykreddy
oh....did u got the issue immediately after August update or after few days bro,
actually I have installed aug patch on 21st aug, from 4th sep onwards iam having issue bro.
Abusaleh77
yess bro... not me my friend also have same problem after an update bro???
