Goodlock module battery draining
(Topic created on: 02-10-2024 07:49 PM)
TMOV
Does using goodlock modules cause any unusual or excessive battery draining
If so comment
10 Comments
akshatb
Actually i dont use good lock so i dont know
TMOV
I used it before in my a50 I didn't notice much of a difference but in s21fe it's pretty bad
akshatb
Where can i get good lock
TMOV
@akshatb in galaxy store
akshatb
Ok
Acc to mine opinion ans is no
But some modules and customization options may vary bro
TMOV
Maybe
Shafique
no Draining
Jitni adhik customization karoge utni RAM & processor bhi use hogi uss customization ko as it is rakhne ke liye to obviously battery thodi adhik drain hogi hi.
60 Hz mein difference low hoga and 120 hz mein high
