Gaming hub problem..
(Topic created on: 05-10-2025 02:11 PM)
shobhut
Hi users,
I am using a Galaxy S23 FE. I am reviewing it after One UI 7. I installed One UI 7 three days ago. It did not install properly, and my phone was very laggy and buggy. I reset my device, and the bugs were fixed. I am an average gamer, and I noticed after the reset and after One UI 7 that my gaming navigation buttons do not show. Please, users, give me a solution.
Samsung, please fix this. This problem only occurs when playing Free Fire Max.
7 Comments
You have one ui 6.1
In this device yes! Will 7 in 2 days
shobhut
Bro please send me solution after one ui 7
Same thing, use same process I did it to my s25 ultra
cs_member8
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
shayamall
Show nahin game ke whatsapp
