Galaxy s7 camera problem
(Topic created on: 05-03-2023 05:13 PM)
Robber2
MY glaxy s7 which i used since 2019, few days ago ,Their (front & rear camera + flashlight) stops working . When i try to turn on camera it appears (camera failed) & when i try to turn on flashlight it appears ( flashlight being used by another app) if anyone know the solution please explain ?
5 Comments
salmanul
Expert Level 3
If you're having issues with your Samsung Galaxy S7's camera or flashlight, here are some things you can do:
1. Restart your phone.
2. Clear the camera and flashlight app cache in your phone's settings.
3. Update your phone's software in the settings.
4. Uninstall any third-party camera or flashlight apps.
5. Reset your phone to factory settings if none of the above works (note that this erases all data, so make sure to back up your important files).
If none of these solutions work, you can take your phone to a Samsung service center or a repair shop to get it looked at by a professional.
Robber2
Thanks for sharing Your info Mr,salmanul . BUT I already tried all of your methods & even factory reset but nothing seems good
salmanul
Expert Level 3
So it should be the hardware failure
Robber2
I also think so
salmanul
Expert Level 3
It's okey bro ..time for an upgrade..♥️♥️♥️
