Galaxy s23 ultra battery issue
(Topic created on: 06-24-2024 04:59 PM)
lunaticquest
Dear focks please update battery backup of your device after June update. Mine draining too fast nearly getting only 4hrs SOT
2 Comments
Samsung_specialist
Battery consumption and lifespan varies depending on a number of factors, including the frequency of device use, the number of installed and running apps, operating system errors, and network connectivity. 5G networks may drain the battery faster, but Galaxy phones use advanced AI-based software to efficiently control battery consumption to suit your usage patterns.
Before you try the recommendations listed in the below link, be sure to check if your device's software and related apps are updated to the latest version.
https://www.samsung.com/ae/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
milos89
Hello, I have a problem with the phone ultra s21 battery life weak it shows when I do diagnostics. I changed the battery, and it's still overheating and restarting. Does anyone have this problem and how to solve it? Maybe CPU is problem ?
