Galaxy S9+ Display Flicker problem
(Topic created on: 02-27-2020 01:43 AM)
Bhanuka
When I turn off the screen and turn on immediately the display flickers and colors change.
I've been look into this problem since past month and I tried all the methods but none of them worked. Some say it's not a display problem it's more of a software problem.
Does anyone have this problem? Or an answer?
6 Comments
Donchamath
do you have warrenty ?
Bhanuka
No. Warranty period is over. Did you have this problem?
Donchamath
yes bro i had the same issue with my previous phone. they said water has gone in to the phone and motherbaod has to be replaced. its not an issue with the display
Donchamath
but i cant assure that its the same problem you also facing better to contact the samsung repair center. and try to get it repaired from them
Bhanuka
Oh I see. thanks bro.
Thanuu
I also have the same issue
