Galaxy S24 Ultra Battery Drain
(Topic created on: 02-13-2024 10:32 PM)
saadd1
Hello friends
Since I bought my S24 Ultra I'm noticing that whenever I charge my phone to 100%, it drains to 99% just within 4 5 seconds.
Is it normal or my phone has issue ?
Please let me know
12 Comments
Miraulder
I also experience similar on mine
Coming from the S23 Ultra it definitely doesn't feel like it lasts long
But I am sure the Software Update that's coming will help with all these bugs
saadd1
I hope so
Miraulder
Same here
Samsung has a few things to work on with this phone...I hope it all aligns well with the updates
NotAdmin
Contact Samsung
Michellej
Having same battery issue. The s23u out the box was hands down better battery wise. Let's hope first official update fixes it
saadd1
Yes, let's just wait for an update.
Because when we complain to samsung care, they also tell the same thing that it will be fixed after an update
Brendtwp
Try turning on battery power saver.
Tendai777
Brand new phones tend to consume battery. This is because your phone will be learning your usage patterns and that's how it will best optimise your apps and battery. It's normal
Tendai777
The phone just learns your usage pattern by learning how you use your phone and what apps you use, putting the ones you don’t use in sleep or deep sleep etc. I guess if you used your phone a different way everyday then it would still notice you using those ‘main’ apps that you are using.
