Galaxy S21 FE has a bigger battery than regular Galaxy S21
(Topic created on: 04-26-2021 12:54 PM)
GalaxyA51user
We had exclusively revealed earlier this year that Samsung will soon launch the Galaxy S21 FE. The phone’s design was leaked a few days ago, and it is expected to feature some of the most important bits of the Galaxy S21 such as a high-refresh-rate display, a triple-camera setup, and a flagship-grade processor. Now, its battery capacity has been revealed as well.
Last year, Samsung had equipped the Galaxy S20 FE with the same battery capacity as the Galaxy S20+, and we had hoped that it would do the same this year by equipping the Galaxy S21 FE with the Galaxy S21+’s 4,800mAh battery. However, that doesn’t appear to be the case. According to our friends at GalaxyClub, the Galaxy S21 FE (SM-G990B) will be powered by a 4,500mAh battery. It uses a battery with model number EB-BG990ABY and a rated capacity of 4,370mAh, but Samsung will likely market it as a 4,500mAh battery (typical rating).
