Galaxy S10 Plus Battery Issue
(Topic created on: 11-23-2019 11:41 AM)
Khanyawar
My galaxy S10 Plus Exynos version is showing very poor performance in term of battery life. It is only providing less than 4 hours of screen on time which is very poor for 4100 mah battery. Please solve this asap.
11 Comments
itsmanishh
visit Samsung service center there may be many reasons for battery drainage faulty sensor or app it will be fixed on Samsung service center
Goldychahal
on android 9 or android 10 beta?
Khanyawar
android 9 it is 😕
Goldychahal
screen on time depends on various factors such as which app you use mostly , your network type , battery drains more on 4g network .. try dark mode.. put apps to sleep which you don't use regularly..
Goldychahal
monitor battery drainage apps in battery settings..
Ravi0883
check some app drain battery in background
Khanyawar
i believe there is some issue in software which needs to be fixed else everything is working fine like usual. No app is draining battery like in unusual way.
Ravi0883
Once reboot your phone
This is battery optimization issue..Samsung kehi durr so raha hai..so forget it..no solution will gonna fix this issue..and after every updates situation is getting worse..no concrete solution till yet..
Still you may try few change in settings like:
Use dark themes and wallpapers
Change resolution to fhd+
restrict background data usage
put unused apps in immediate sleep mode
Change AOD settings to "tap to show" mode
Turn off bluetooth/NFC and wifi..if they are not required
Turn off auto sync..
Restart your device atleast 2-3 times in a week..
Scan your device from time to time
Try not to use too many 3rd party unnecessary apps
