vasto
05-30-2019 11:58 PM in
Will Samsung provide a permanent fix for the Galaxy S10 series notification LED? Even with the Edge Lighting+ app, most of the time the LED Notification doesn't work when the screen is turned off expect for the standard built in apps. Why can't the notification LED glow for the other apps? Please Samsung, it's a humble request, kindly take some due steps to fix this issue with your flagship.
6 Comments
Not applicable
05-31-2019 12:14 AM in
Exactly, what is the use of this LED if it doesn't work when screen is turned off.
Pls fix this issue.
Pls fix this issue.
Sidhabhi
05-31-2019 05:07 PM (Last edited 05-31-2019 05:07 PM ) in
For what apps you guys are not getting notification light,its working fine for me. Do one thing..if it's for whatsapp,go to settings,then notification part and turn on notification reminder pop up as always on,follow the same for other apps which has pop feature,then only it will gonna work. I hope this will help..
38 KB
Sidhabhi
05-31-2019 05:07 PM in
Also,keep edge lighting option as always on and notifications on for all required apps.
Not applicable
05-31-2019 05:17 PM in
It is working fine for me as well. but i was talking about when screen is turned off.
After 10 sec you don't know that you gpt any notification there. because there is no LED notification for such.
vasto
06-01-2019 08:33 AM in
but turning on the pop up notification is not a permanent fix. You are just adjusting to what you are getting. This is not how it is supposed to be. The notification LED is supposed to work even without the pop up notification and with the screen turned off.
subhashganesha
07-07-2019 10:38 AM in
Galaxy Sgood post
