Galaxy S10+ Edge Light
(Topic created on: 03-31-2019 01:29 AM)
alanapandaa
Hi. Galaxy S10+ Edge Light is not working when the screen is off, eventhough the setting is already in the ALWAYS option in Show Edge Lighting. Please update/fix. Or please help me what should I try to do to make it work. Thank you.
12 Comments
ahmedabid
same problem I have with S10+
Right now there is no fix for this issue. Issue is with third-party apps only. Hope samsung will fix it in future update.
musalam
you can maybe turn on from settings , I hope help you
ahmedabid
problem solved just update your phone
musalam
i have a last update
alanapandaa
does the edge light works now when screen is off? cause mine still doesn't.
iRozen
Just use a third party app for the mean time. you can use AOE (always on edge), it's free.
fredo
I have the same problem with a s10+, latest update installed.
hope this will be fixed soon, because this is the point of notifications... to let you know you have a mail, a text, even when your screen is locked...
alanapandaa
hopefully they will update the system and includ an indicator. like around the front camera since there is no led light 😁
