Front camera issue
(Topic created on: 04-13-2025 05:26 AM)
Binula
My new galaxy s24 ultra is having an issue with the front camera since I bought it(a month ago). The camera won't turn on for a period of time after a restart. Sometimes it turns on and works normal. But recently it doesn't turns on at all. I have done all I can but still it is the same. Anyone knows why this happens? I HAVEN'T TRY FACTORY RESETTING THE PHONE YET.
6 Comments
Binula
Yes have done many times
Where did you purchase from? Sri Lanka or..?
Binula
Sri lanka
Chathula
Try a factory reset or software update. If that doesn't work, it's likely a hardware problem. If you've only had the phone for a month, go ahead and claim the warranty immediately.
Hi, I'm sorry to hear that. This can be a hardware or software issue. To make sure that the software side is working, you can do 2 things which you haven't already done.
#1 Reboot into safe mode, if the problem solves itself I think we can agree it's a software issue.
#2 a factory reset.
If it is a hardware issue, you need to claim a warranty immediately!
I hope this helps!
If my comment helped you figure things out at all, please consider tapping the three-dot menu and mark it as a solution. Your support fuels the community! Thanks for being part of it!
