Following issues I am Facing in My Samsung S7 Edge after Android-Nougat update
(Topic created on: 02-05-2017 08:59 AM)
SD
1-Can't download or update anything from playstore(only) in Roaming Network .
2-Charging takes more than 40 minutes to charge 40-50% and more than One hour 40 minutes to fully charge the phone.
3-Battery draining like a water on a sand ☹ .
4- Some time getting very hot while playing games .
5-Edge Lighting which is Exclusive feature of Samsung Edge Series is no more compatible with S7 Edge after update.
Conclusion- Nougat update by Samsung brings more cons than pros ....So Samsung we as your valuable users want;; please resolve these issues.
10 Comments
Samsung_India_
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
