Fix Lag and Battery Drain After Software Updates!
(Topic created on: 02-11-2026 10:49 AM)
Drfaiz
Title: Tip: Fix Lag and Battery Drain After Software Updates!
Message:
Hi everyone!👋
If you’ve noticed your Samsung phone feeling slow, laggy, or having battery drainage after a recent software update, you aren't alone. Often, old temporary files from the previous version conflict with the new update, causing these issues.
The best way to fix this without losing any of your photos or apps is to Wipe the Cache Partition. This "cleans out the junk" and lets the new software run smoothly.🚀
How to do it (Step-by-Step):
  1. Power Off: Turn your phone completely off.
  2. Connect USB: Plug your phone into a PC/Laptop or use USB-C headphones. (Most newer Galaxy phones require this to enter the menu). Some phone didn't require
  3. Enter Recovery Mode: Press and hold Volume Up + Power until the Samsung logo appears, then release.
  4. Navigate: Use the Volume Down button to highlight "Wipe cache partition."
  5. Select: Press the Power button to select it.
  6. Confirm: Scroll to "Yes" and press the Power button again.
  7. Reboot: Once it says "Cache wipe complete," select "Reboot system now."
Your phone might take an extra minute to start up, but it should feel much faster and more stable afterward!
Hope this helps someone else! Let me know if you have questions.😊
GalaxyA07
