Resolved! Solved
Feedback Samsung and Solution
(Topic created on: 11-11-2023 11:27 AM)
UserAdik
Not a Samsung issue its a developer issue
5 Comments
UserAdik
Fasalu737
Update the app in play store
Samsung_specialist
As mentioned in the attached message, the app you are trying to install is having a bug. So, try to update it, Uninstall and reinstall it and observe If the issue has been resolved or not.
Hi dear
I try doing what you are writing but still not working
This happened after updating to UI6
