Edge notification not working
(Topic created on: 10-16-2016 07:16 AM)
Jomet
Hi
In my new S7 edge the notification doesn't appear even after multiple time I swipe on edge of screen.
I've set all edge notification on but still it doesn't work, any else is required for that to appear?
admin_1
Please apply the following setting( “Do not show notifications” if you set like this) to “Show content”. Settings -> Lock screen and security -> Notification on lock screen -> Content on lock screen -> Do not show notifications.
You may send Error report if the problem persists.
Samsung members(Preloaded Application) -> Feedback -> QUESTIONS/ERRORS -> Send feedback (bottom right corner)
-> Select type -> Error reports ->Send system log data(To be checked) -> SEND(upper right corner)
Our engineers will analyze the case further and will give you a feedback on that channel.
