lostpraveen
Earlier the edge lighting would work smart enough, now with the updates Samsung made it dumb.
Earlier, edge lighting notifications would work only when the screen was off. Now it works all the time, I know there's option to turn it off when screen is off. But I want the reverse feature, it should activate only when screen is off, not when I'm working on screen.
Samsung deliberately takes away good features.
OptimusPrime108
Agreed. Give feedbacks. This can be easily implemented with future updates.
