Edge Lighting Issue in Galaxy S10 Plus
(Topic created on: 08-23-2020 08:06 PM)
MrTitanium
When Phone faced down, the edge lighting feature not working when receiving calls or notifications in my phone.
Any solution to fix this.
Thanks in advance.
10 Comments
For, you only i just tried it..its working fine..please check all settings of edge display
AGalaxyuser
Expert Level 4
which case??
@Rashel..bro..avenger case..bought from flipkart..
AGalaxyuser
Expert Level 4
Really nice iron man😁😁😉😉
MrTitanium
This is my setting. It still not working.
veer
go to systems app serch edge lighting one time clear data than try
Check this
MrTitanium
Already Checked, but still not working.
Bro, once perform normal phone reset settings
settings>general management>select reset>click on reset settings
and also if possible uninstall edge lighting+ and install it again
