EDITED, Please Let me know, how to avoid problem post-update issue this ONE UI8
(Topic created on: 09-30-2025 08:10 PM)
Nik011
Dear Samsung Team,
I own Galaxy S24 FE. I got an update of One UI8. But i am afraid to do it.
 Because Lots of Post I have seen that after updating One UI8,
Battery Drain Issue
Camera Quality Drop
OverHeating Issue.
Display Green Line Issue.
and Many more.
So, dear Samsung.
Give us the solution to avoid these during an update.
EDITING POST AFTER UPDATING MY PHONE TO ONE UI8, Android 16.
If It is 3.3 GB File.
Its very Stable. No need to fear.
Just update it in cool place. After updating, Only Reset all Settings.. no need of Factory Reset.
I have positive results. So, I am happy.
1. Heating Issue is somehow reduced. (at current ambient temp. 32°C no any problem.)
2. Battery Health is same as before.
3. Camera results also same as before.
9 Comments
ArunKanavaje
Dont worry...its working perfectly
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would like to inform you that the latest software update has been developed to enhance both the performance and stability of your smartphone. This update has undergone thorough testing at various stages to ensure reliability.
While we acknowledge that issues can arise due to individual usage patterns and other factors, we want to assure you that our dedicated customer support team is always here to assist you in resolving any concerns that may occur post-update.
We encourage you to proceed with the update confidently, knowing that we are committed to providing help and support if needed as per policies.
ram_ram
Expert Level 4
It is very difficult to get free replacement of display from Samsung in Green line problem update in your own risk can't avoid Green line
Nik011
ram_ram
Same. That I fear of it.
Samsung should take responsibility for the problems post update.
Otherwise every samsung user should go to customer Care.
And update the phone in front of Samsung Staff.
Hydes1
How's the battery backup, I also want to purchase s24fe
Nik011
Needs 2 times full charge per day.
Also it has heating issue in summer season.
With sunlight 37°C its heating naturally more.
Then, within normal use its temp. Increased 5° means 42°.
Thats not an problem. But it feels pressure in mind because its expensive mobile.
Better to buy s24 with snapdragon
AnverAli
I’ve also ended up with a pink line right at the center of my display. The phone was bought in the UAE, but I’m currently in India — and apparently, that’s a big problem. Samsung India says they can’t replace the screen for overseas models, and Samsung UAE says they can’t help unless I’m in the GCC. So basically, I’m stuck right in the middle… just like that pink line. 😅
