Door acess card
(Topic created on: 08-06-2024 11:22 PM)
winmn
Beginner Level 4
Hello
Anyone, could you tell me please how to add door access card to samsung wallet?
If we need to use some third party apps, please share your experience please.
3 Comments
JupiterGuy
Have you tried the smartThings app?
Shoung
You can use smart door only which is supported in smart things to use by samsung wallet
Samsung_specialist
You can only use door locks that work with SmartThings.
To begin, first open SmartThings and add a compatible "Dook Lock"; this will activate the "Add Digital Key" menu in your Samsung Wallet app.
* Door key direct activation in SmartThings to be added soon.
You can go to the FAQs then Digital Home Key for more detalis
https://www.samsung.com/ae/apps/samsung-wallet/
