Display problem
(Topic created on: 08-18-2021 12:39 PM)
Saman17
My S9 Plus screen is turning green. Is there anyone else facing the same issue? How to solve the issue?
Picture taken from google.
6 Comments
Asadamjadali
It might be screen issue.I suggest you check it from mobile repairing market
AhmadJs69
Panel change hoga I think
Saadi121
Panel heat up ho gya damage ho gya ha
Ap ny zaida use kia mobile heat up hua to circuit break ho gya
Asadamjadali
Yes it is that
Saadi121
Good
AemanMalika
Hello sir..Meray Old phone Samsung C9pro me aisa hua tha..screen green ho k vibrate krti thi..Check krwany pe pata chala Screen Panel kharab hai..I remember mery phone me pani be gya tha..So Menay change ni krwaya coz its cost was 15k..But Kuch arsa bad khudi thek ho gya mera😂
