Resolved! Solved
Display lag using Motion smoothness on Adaptive mode.
(Topic created on: 01-21-2022 05:25 AM)
Chengiss
As the title explains itself after the last update using Motion smoothness on Adaptive mode (S21 Ultra) has been a pain in the **bleep**.
No matter what i did i could not fix it. I dont think it has a specific reason to do so too it just randomly happens. checked RAM usage Battery power etc. and well the phone itself is only 2 months old to begin with. I just think its a simple bug after the update and i hope it get fixed as soon as possible.
Tosunpaşa
You can control it by getting remote support through this application.
2 Comments
Tosunpaşa
Tosunpaşa
Translate de olmasa 😅😅
