Direct call edge screen not working after Android 10 update.
(Topic created on: 01-21-2020 10:32 AM)
OSss08
The Direct Call edge that I used to use frequently has stopped working after the android 10 upgrade. If I remove the contact from the edge and re-add it, it works once but then stops working again if u try it for the second time. Any solutions?
3 Comments
Samsung_specialist
Hello,
Can you please contact our call center on 800 7267864 and request Remote Management to help you with your concern.
Thank you
OSss08
Contacted Samsung the issue did not get resolved. However I checked the Galaxy store for Direct Call Panel and there was an update waiting. I updated it and now its working. I dont know why this was not updated automatically. But this update solves the issue.
shatra
Beginner Level 3
thank you....was going crazy due to this issue... issue solved now
