Dialpad Settings Problem.
(Topic created on: 05-27-2025 01:29 PM)
Masums
After updating to UI 7 on S23U, the call background is not changing. When I receive a call, when I hang up, the vibration does not occur even though the vibrate mode is on.
The same problem persists even after I applied the May patch update. What should I do now?
3 Comments
goodthings
Please reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually also update your's all apps too also reset call settings then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
