Degraded Camera Quality S 22 Ultra
(Topic created on: 2 weeks ago)
drvksah
I noticed for last 3 months ...camera Quality degraded sharply. I have seen One plus,Vivo n I phone....all having superb Quality with time passed. But wats happening to Galaxy ?
Samsung must look in their flagship smart phone.
5 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
drvksah
Everything done.
Even Service center.
Nothing noticed...
drvksah
Will try again again for best results
