Concern Over Battery Life
(Topic created on: 03-24-2019 08:58 PM)
VGmaniaz
This Battery Life Expectancy Is Normal or My device Battery is Performing Low .
Please Advise
6 Comments
PurshuRana
show the last full battery usage
sen001
You seemed to use your device a lot for online contents. So its normal.
kushal
it's normal.
kapilmalik
it's normal. the more you use, the battery consumption is higher in Samsung phones
Anshu
Looking at ur usage it seems to be good
Monu18
Disable volte on one sim, it consumes significant amount of battery when volte of both the sim is active.
