Charging problem
(Topic created on: 05-14-2020 08:52 PM)
Waqasii
It's been 16 month i buy new s8plus now having charging problem it's not charging with cable only wireless charging working any good suggestions what can i do??
7 Comments
Justicex
Beginner Level 3
try to turn it off and charge it while it's off.
Waqasii
I'll try but its not working
MohammedSijah
First try with a different data cable and then with a different charger.
Waqasii
MohammedSijah
If you are not getting any response while plugging in, you may visit the nearest service centre.
Waqasii
Okay thanks
Samsung_specialist
Hey there,
Please visit the nearest service center to check the issue you are facing by our team.
www.samsung.com/sa/support/servicelocation/.
Thank you
