Charging issue
(Topic created on: 2 weeks ago)
myselfhorizon
My phone charging stops and starts again and again whenever its reachs near to 90% check the video below.
Charging starts and stops again and again
10 Comments
goodthings
Kindly reset factory data with backup then try to it's again. If not resolves then go to service center for check and resolves this issue. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
Do check Battery protection
Chinunick39
What a knowledge.........
If i am wrong then you can correct me tho
Chinunick39
This is a bug......Otherwise, if he does the diagnostic, he will find out.
And if this is battery protection then charging will stop there and will not start again, try it and see.
Ahh now i got it thank you for clarifying
myselfhorizon
But why its happening only it reachs to 90%. I tried changing the cable and its kinda resolved but i am curious to know why its happening with original cable
Can you send the ss of device care / battery / battery protection?
