Charging issue
(Topic created on: 10-15-2025 09:03 AM)
JoshithNamburi
From recent few days im getting this on my Samsung galaxy s21 fe 5g sd 888 i called to service center and they told me that the charging board issue and super fast charging also not working and they said the board costs me around 2500 sometimes it works normally and super fast charging also but rest of the time it getting like this the above picture i don't know what to do now so anyone if you are facing same issue can you please help me to rectify the problem but the charging port doesn't have any moisture i never touch my mobile with wet hands but it is showing like this so anyone can help me to get rid of this
9 Comments
Pani me gir gaya th Kiya phone ya cable
No
Charging port me phone ya cable me dust baith gaya hoga S24 me Normal hai yh Dekh kr bata woo dust ho ga Charging wale pin me
Arit1011
YOUR_EX
Dear, if u having a charging issue in your Device. Please clear your device charging port nd your charging cable to. Then try to charge.
If u find this is helpful Click on the three dots of my replies right corner nd accept the solution 😊
goodthings
Kindly complaint to Samsung customer care support through Samsung Members App as error report also send log files along with this error report for this issue and go to service center for check and resolves this issue. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As you have already coordinated with the service center team regarding your device display issue, they have provided you with information after inspecting the device physically, as per Samsung guidelines. Please be assured that they have given you all the correct information regarding the repair process.
We suggest that you visit the service center again and submit your device for further processing. Rest assured, we will provide best-in-class services, and the repair will be carried out by trained and certified Samsung engineers. Additionally, all parts used will be genuine.
Chybinod
I have same problem with my S25 but there isn't have any issues that mentioned in the below
