Charging issue
(Topic created on: 06-18-2024 10:47 AM)
Nour2235
Hi i usually use the fast charging to charge my phone s23 ultra suddenly the fast charging stopped and the phone take only normal charging i changed the adapter and caple the phone took fast charging for tow days then i faced same problem
4 Comments
bb91_S23ULTRA
May I know if you are using a 45 watt Samsung charger?
Nour2235
Yes samsung 45 watt original charger
Try using a urgeen, belkin or anker charger
Samsung_specialist
For optimal performance, use a Samsung authorized fast wireless charging pad and/or the in-box adapter.
- Fast Charging 1.0 needs the adapter which supports above 15W power (max 9W charging power)
- Fast Charging 2.0 needs the adapter which supports above 25W power (max 15W charging power)
https://www.samsung.com/ae/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
