Charging issue
(Topic created on: 01-09-2023 05:12 PM)
Mandar080
Charging is paused at 84% while Protect battery is on.
8 Comments
Drax55
Battery will only charge up to 85% you can turn off protect battery ti charge till 100%
Mandar080
It is paused at 84 and not 85, kindly look at the battery percentage
H3X7
85 is nice it nit make your battery old or drain it
princepapi
Tell me the solution to this problem. My s10pluse display in tow spots IMG20230109173527_14089_1673266065.jpg
Gaming6698
I think your phone charged to 85% then after sometime it drains to 84%.
_Sara_
Expert Level 4
It can't be cus it's still in charge
_Sara_
Expert Level 4
Is this the first time happening? If yes, then just restart your device and see
GuruKratOs
Restart your mobile and check it bro...it happens occasion or regularly
